.eps files
   14295   17   3
H9 file import lists a .eps file as readable , yet I cannot get a .eps file from illustrator cs to work ?.
Rob
Gone fishing
I think it actually imports old adobe illustrator (.ai) files named with the .eps extension.
you could possibly convert the eps to a bgeo file with the command line utility,
geps, which comes with houdini.
eps files are problematic since there are an endless number of flavours.
“everything is coincident”
Using geps additionally allows one to perform conversions on the command line. The File SOP automatically calls geps to perform the conversion when given a filename with the extension ending in .eps. The real problem is that the “.eps” files that geps understands are actually .ai files.
Thanks so much for the answer. I had a bash at it, created a .bat file to run in the cmd line but I cannot get it to run correctly.
#Usage: geps infile.eps outfile.*geo
So I input
C:\Program Files\Side Effects Software\Houdini 9.0.748\bin geps.exe
C:\Documents and Settings\circusmonkey\Desktop logo_CMYK.eps
C:\Documents and Settings\circusmonkey\Desktop CMYK.*geo
but I get this error
C:\Program Files\Side Effects Software\Houdini 9.0.748\bin>C:\Program Files\Side
Effects Software\Houdini 9.0.748\bin CMYK.*geo
'C:\Program' is not recognized as an internal or external command,
operable program or batch file.
I know its my fault as to why its not running ..any pointers ?
Rob
Gone fishing
Rob! Spaces in the path! Does it say something to you?
cheers,
sy.
PS (hint: a quotes…)
Ahh of course the “”
Rob
Gone fishing
well you would of thought this would be simple , but no.
.bat file = failed
Houdini command line
G:\Projects_vfx_houdini\GFI_LOGO\geo> geps glogo.eps logo.bgeo
Token %%Note: not found.
Unable to convert EPS file glogo.eps
can anyone or should I say has anybody ever got this to work. Id love to know what token is being looked for and where I am suppossed to put it lol
Rob
Gone fishing
Really, after *years* of complaints the EPS import is still not working?
Truly remarkable.
Dragos
Dragos Stefan
producer + director @ www.dsg.ro
www.dragosstefan.ro
edward
edward
edward
I tried right now to import a very simple (one rectangle) Illustrator file, in AI3 format, exported both as ai (extension changed to eps) and real eps, and got erros on both versions, in Houdini as well as in geps.
Dragos
Dragos Stefan
www.dragosstefan.ro
Your illustrator file can only have outlines. No fills.
Need to convert to outlines.
Save as a version 3 illustrator file or export to .dxf.
Here is a script for Illustrator that exports Houdini readable eps files. Not written by me.
http://www.preset.de/2007/0705/illustrator/ [preset.de]
Works great btw!
While on the subject, is there any way at all to get curves OUT of Houdini? Preferably to a Rhino-readable format. Many formats don't support curves at all, and .eps is… not working.
Best, Fredrik
I saw that script . The only snag is I do not have illustrator2. In the end I gave up with .eps. I could of just fired up Maya but that would of been a cop out. In the end I went.
Trace SOP to read in the logo as a image and a combination of Curve SOP > Resample SOP > Carve SOP. Although it was a fiddle at least I got the job done
Rob
Edited by - Oct. 16, 2007 22:13:38
Gone fishing
Fr3drik
.iges ?
Thanks, .iges worked like a charm. Thought I had tried all formats…
The real problem is that the geps require %AI3_Note: (obsolete now) tag in .eps file
so…please fix this annoying bug in geps.exe
2circusmonkey:
Just open eps in text editor and add
%AI3_Note:
line manually
