How to assign shader to DOP Objects ?
2823 1 1- newPeak
- 83 posts
- Allegro
- 696 posts
if you're asking how to apply materials to a dopnet, the answer is you don't
It's generally a bad idea to attempt to render dopnets, instead you should be importing the geometry or visualization of your dynamics into a geometry object and applying materials the way you would to any other object.
Try using the shelf to convert a sphere into an rbd object to see the workflow for bringing objects out of dops.
Stephen Tucker
VFXTD
VFXTD
