Transforming matrix with python API ignores translation
   1564   4   1
Using the houdini (20.5.305) python API, I created a transformation matrix that I would like to use to rotate and translate a camera.
The rotation gets applied, but the translation of 5 units in xyz is completely ignored. Am I misunderstanding how to perform this transformation correctly? Thanks!
import hou
cam = hou.node('/obj').createNode('cam')
transform_matrix = hou.Matrix4([
    [1, 0, 0, 5],
    [0, 0, -1, 5],
    [0, 1, 0, 5],
    [0, 0, 0, 1]
cam.setWorldTransform(transform_matrix)
print(cam.worldTransform())
Console output (notice the final column reset):
[[1, 0, 0, 0],cam.pre
 [0, 0, -1, 0],cam.pre
 [0, 1, 0, 0],cam.pre
 [0, 0, 0, 1]]cam.pre
cam.pre
Edited by hzwus - Feb. 6, 2025 14:15:52
Houdini uses the last row for the translate vector or uses the transposed method of the matrix4 object before applying.
In other words most matrices in Houdini are in Row Major order so bear that in mind overall when doing matrix operations in Python or VEX as that may also imply different order of operations than you are likely expecting if you are used to operate Column Major matrices
Edited by tamte - Feb. 6, 2025 17:56:25
Got it, thank you!!
It's worth noting VEX sometimes uses column major convention for matrices. For example the gradient matrices returned by volumesmoothsamplev [www.sidefx.com] and volumecubicsamplev [www.sidefx.com] functions.
The grad is a matrix whose i-th column is the gradient of the i-th component of the volume.
To align this matrix with the row-major convention, you need to transpose it.
There are other VEX functions that exhibit this issue.
RFE pending to document these more thoroughly.
