I am just beginning to really dive into Houdini more deeply, as I have only played around with it in the past really. I have been getting into the fluid simulations and dynamics area right now (still very much a beginner in this area), and I have been looking for tutorials on how to set up a fluid tank to have a continuous current. I have not found any unfortunately, only ones on objects moving into and out of a tank. So my question is:
How do I create a Fluid Tank that has a continuous current to move fluid particles past whatever collision geometry is placed within? (for testing like boat wakes, beach waves, etc. for example)
I have set the velocity in initial data to move in the X direction, and to kill particles at the opposite end but that just empties the tank since no particles are being created. It is probably right in front of my face but I have not found the area/node to tell it to birth more particles to create the
continuous flow. What am I missing? Is there a better route?
Thank you in advance to anyone who can help.
How to create a continuous Fluid Tank current?
2118 2 1- Dustin Tarr
- 12 posts
- Enivob
- 2536 posts
Have you tried adding an Emit Particles object to your setup? If your tank is emptying then you need to fill it. This will create a continuous flow.
Here is an example. After the tanks empties the in flow object keeps particles flowing in the X direction.
Using Houdini Indie 20.0
nVidia 3050RTX 8BG RAM.
- Dustin Tarr
- 12 posts
Enivob
That's pretty sweet, Thanks Enivob! That is right down the route I am looking for. Ill rebuild myself just for learning's sake and then tweak to see what I can get out of that. Only question, was there a parameter that allows the particles from the box_in to grab the initial velocity of the tank's or is that just automatic from the source being fed into the flipsolver? Again, pretty cool. Thanks a lot.
Houdini Indie
Windows 10 Intel i7-5820K @ 3.3GHz
MSi Nvidia GeForce GTX 980 Ti 6 Gb
16 Gb RAM
16 Gb RAM
