vartex animation texture of rigid does not match data on houdihi
4751 7 1-
- ankoro
- 7 posts
I want to output rigid's vartex animation texture and let it play with unreal engine,
The position is slightly off and does not match the preview of houdini.
It is in a state that does not fit each little.
Reading procedure
Read fbx data and rot, position map.
Each texture is vectorDisplacement
Read rigid code into material and connect each.
At this time tangent space normal is off
Create a material instace and connect each map and material.
Combine the setting of each Bounding and Number Of Frame with houdini.
Turn on Use Full Precision UVs of mesh read by FBX
Make Vertex Color Import Option Replace
Assign material to mesh
Is there anything else I need to set? What?
Reading procedure
- mikelyndon-sesi
- 394 posts
- ankoro
- 7 posts
- mikelyndon-sesi
- 394 posts
- ankoro
- 7 posts
- mikelyndon-sesi
- 394 posts
- Seaton
- 22 posts
Same issue here! I am using Houdini 17.5, Game Development Toolset 1.163 and UE 4.22.
I find that BBOX MAX 1 and BBOX MIN 1 are always 0 even the ground plane under 0.
Even a very simple scene, I still can't get an expected result. Can you make an online document for VAT so we can review step by step?
Edited by Seaton - 2019年5月23日 03:37:53
- mikelyndon-sesi
- 394 posts
