Hope someone can help. Thanks in advance!
How to correctly use ROP Alembic
5332 3 1-
- ralphymeijer
- 16 posts
I'm testing some setups to automate some vellum sim jobs where I load different type of collision objects coming from shots,process them and then write out the result per shot to alembic. The first bit is working fine as expected where I load in the collision objects with a file pattern, in this example I have 3 objects. Then I use the Rop Geometry to process them for 150 frames, creating a total of 450 work items. I then partition them based on the original object so I got 3 work items again. This is what I feed in to the Rop Alembic. This is where I can't get it to work and it's probably my lack of knowledge of PDG. What is the correct way of using the Rop Alembic in this case. I tried looking at the examples but that only handles single frame alembics.
Edited by ralphymeijer - 2019年9月9日 17:08:11
- kenxu
- 544 posts
- ralphymeijer
- 16 posts
Thanks for your reply!
I expected that since it sort of worked when I tried that before. However is there a way to sort the workitems based on for example an attribute. Now the workitems are sorted the following: box.0001.bgeo, sphere.0001.bgeo, torus.0001.bgeo, box.0002.bgeo, sphere.0002.bgeo etc. It would be handy if I could sort them box.0001.bgeo, box.0002.bgeo, sphere.0001.bgeo, sphere.0002.bgeo etc. That way I can still split them in the wanted files based on the frame range.
- ralphymeijer
- 16 posts
