I have an older file that loads and renders (in Karma) a bgeo.sc file created in 17.5.293
Using today's build (18.0.367 Linux) however any attempt to load in this bgeo.sc fails.
Reference LOP, File LOP etc.
When I try the Stage manager, and browse to the path where the bgeo.sc file lives, the file browser is empty as though it doesn't recognize bgeo or bgeo.sc files.
Even using a SOP Create LOP fails, the file SOP inside loads the .bgeo.sc and shows it to me in the standard Houdini viewport, but back in LOPs no primitives are created from the SOP Create LOP.
Has something broken or is something in transition or has the process changed somehow recently and I missed the log entry?
Peter B
Q: Are Bgeo.sc files busted in 18.0.367?
5684 10 4-
- pbowmar
- 7046 posts
- pbowmar
- 7046 posts
Maybe related, likely not, I get this shizzle in my shell:
ERROR: /tmp/houdini_temp/hfs5024-7.tmp (6): Hotkey symbol “h.pane.gview.state.lop.stagemanager.key_translates” not found
ERROR: /tmp/houdini_temp/hfs5024-7.tmp (7): Hotkey symbol “h.pane.gview.state.lop.stagemanager.key_rotates” not found
ERROR: /tmp/houdini_temp/hfs5024-7.tmp (8): Hotkey symbol “h.pane.gview.state.lop.stagemanager.key_scales” not found
ERROR: /tmp/houdini_temp/hfs5024-7.tmp (12): Hotkey symbol “h.pane.gview.state.lop.stagemanager.set_keyframe” not found
ERROR: /tmp/houdini_temp/hfs5024-7.tmp (13): Hotkey symbol “h.pane.gview.state.lop.stagemanager.del_keyframe” not found
ERROR: /tmp/houdini_temp/hfs5024-7.tmp (17): Hotkey symbol “h.pane.gview.state.lop.stagemanager.reload_state” not found
ERROR: /tmp/houdini_temp/hfs5024-7.tmp (19): Hotkey symbol “h.pane.gview.state.lop.stagemanager.log_state” not found
ERROR: /tmp/houdini_temp/hfs5024-7.tmp (29): Hotkey symbol “h.pane.gview.state.lop.stagemanager.duplicate” not found
ERROR: /tmp/houdini_temp/hfs5024-7.tmp (30): Hotkey symbol “h.pane.gview.state.lop.stagemanager.delete” not found
ERROR: /tmp/houdini_temp/hfs5024-7.tmp (31): Hotkey symbol “h.pane.gview.state.lop.stagemanager.group” not found
ERROR: /tmp/houdini_temp/hfs5024-7.tmp (32): Hotkey symbol “h.pane.gview.state.lop.stagemanager.copy” not found
ERROR: /tmp/houdini_temp/hfs5024-7.tmp (33): Hotkey symbol “h.pane.gview.state.lop.stagemanager.cut” not found
ERROR: /tmp/houdini_temp/hfs5024-7.tmp (34): Hotkey symbol “h.pane.gview.state.lop.stagemanager.paste” not found
ERROR: /tmp/houdini_temp/hfs5024-7.tmp (36): Hotkey symbol “h.pane.gview.state.lop.stagemanager.edit_variant” not found
ERROR: /tmp/houdini_temp/hfs5024-7.tmp (48): Hotkey symbol “h.pane.gview.state.lop.stagemanager.reset_pivot” not found
ERROR: /tmp/houdini_temp/hfs5024-7.tmp (50): Hotkey symbol “h.pane.gview.state.lop.stagemanager.clear_info” not found
Peter Bowmar
____________
Peter Bowmar
____________
- pbowmar
- 7046 posts
- mtucker
- 4589 posts
It sounds like the BGEO file format plugin for USD isn't getting loaded. Can you try running Houdini after setting
TF_DEBUG=PLUG_*
and make sure that the plugins in $HFS/houdini/dso/usd_plugins are being loaded?
If not, do you have a custom HOUDINI_DSO_PATH set? Or a PXR_PLUGINPATH_NAME set? Or any other unusual features to your environment? Do you see the same problem on Windows, or just Linux?
TF_DEBUG=PLUG_*
- anon_user_37409885
- 4189 posts
- pbowmar
- 7046 posts
Hi Mark,
Same as goat, nada being spit out but can't load bgeo.sc files.
I also notice that Hqueue is quite flaky (machines dropping for no reason) in 18.0.367. Perhaps unrelated, but thought I'd mention it.
I can't easily test Windows currently, but if I get a chance I'll give it a try.
Peter B
Peter B
Peter Bowmar
____________
Peter Bowmar
____________
- mtucker
- 4589 posts
I'm pretty sure the problem is a difference between Linux and Windows. When starting up Houdini we add entries to the PXR_PLUGINPATH_NAME variable (which USD uses to find its plugins). This doesn't seem to be working on Linux, so the plugins in $HFS/houdini/dso/usd_plugins aren't being loaded (these plugins include the karma and Houdini GL render delegates and the BGEO file format plugin). I'll try to sort this out…
- mtucker
- 4589 posts
- pbowmar
- 7046 posts
- 4189 posts
- pbowmar
- 7046 posts
