Motion vector AOV in Karma
8307 16 5- haymaker
- 7 posts
- TangheStudent
- 88 posts
- jerry7
- 626 posts
- TangheStudent
- 88 posts
- No_ha
- 122 posts
Just to note this. As far as I can see, the velocities described in this thread are only taking into account the velocity on the geometry not the geometry relative to the camera.
But I also can’t give any explanation on how to create a proper motion vector AOV like in mantra.
Edited by No_ha - 2022年5月29日 02:42:35
- arx_anima
- 80 posts
- jerry7
- 626 posts
arx_anima
the karma node or the karma standart rendervars node has motion vectors and velocity aov as default to check.
We used them already in production and they work fine, they do not use primvars but a ray level check
ray:motionvector
ray:velocity
I tried ray:motionvector and ray:velocity, but can't get the result.
Could you give any tip?
- mark
- 2593 posts
- agastyafx
What's the difference between motion vector and velocity. Is it with respect to camera? I'm getting data rendered in motionvector but not in velocity
arx_anima
ray:motionvector
ray:velocity
- 7802 posts
agastyafx
What's the difference between motion vector and velocity. Is it with respect to camera? I'm getting data rendered in motionvector but not in velocityarx_anima
ray:motionvector
ray:velocity
motionvector is a screenspace vector, useful for post processing applications of motion blur. I'm not sure what ray:velocity is, but it's probably in world space.
- ysysimon
- 75 posts
jerry7arx_anima
ray:motionvector
ray:velocity
It's seems to be a Houdini19.5 things.
- APESTARSTREAK
- nicolaas.tanghe
- 44 posts
- pranesh arry
- 14 posts
arx_anima
ray:motionvector
ray:velocity
Hey there,
I tried checking both the motionvector and velocity in the karma render node, however I still get a blank output. Am I missing something?
Pranesh Arry
3D Generalist at North Studio
- 0x384c0
- 3 posts
For motion vector to appear in renders do not forget to setup "Motion Blur" in Karma Render Properties [www.sidefx.com] and cache [www.sidefx.com] your animation.
Edited by 0x384c0 - 2023年6月21日 08:46:15
- digones
- 4 posts
pranesh arryarx_anima
ray:motionvector
ray:velocity
Hey there,
Thanks!Image Not FoundImage Not Found
Have you managed to make it work? I've been stuck trying to output AOV motion vectors with no sucess
- npetit
- 360 posts
