Hello, I'm using Houdini on steam.
As the title says, I can't find this recipe.
It works in the FX I use for work.
Is it not included in the Steam version, or do I need to install the recipe
how to load Otto Muscle and Tissue Simulation racipes
1606 3 2-
- jimejime.shadow
- Liesbeth_Levick
- 116 posts
Hi, please contact support about this, the only version where the Otis Muscle Recipes aren't made available is Houdini Core.
I'm assuming that you're trying to load it at the Geometry level and not at the Object level, right?
Does the Otto SOP load correctly? If it doesn't then the problem is probably with your SHFS folder. Support will be able to help you with this.
Liesbeth Levick
Technical Director: CFX
- 7on7on
- 23 posts
I have the same problem. I installed the latest version of Houdini Apprentice (21.0.700) to test Otto. I get an error message saying it can't find the geometry when I add Otto to the scene. I set the shfs variable to an accessible path, but the testgeometry_otto folder is empty, as you can see in the screenshot I've attached to this message.
Did I miss a step? Can you help me?
- Liesbeth_Levick
- 116 posts
