Crowd Sim Troubleshooting
   623   1   1
I am trying to make a crowd simulation in houdini. However I'm struggling with the transitions of the animation clips the agents have.
Is there a way to make a crowd motion path trigger specific to each agent? I want a different trigger for each of the agents.
SOS
thank you!
For motion paths, the triggers are represented just as point groups on the motion path points so you could use other SOPs to generate the triggers if you need something very custom. Otherwise, you could also use the random delay options, etc to produce some variation between agents
