point animation issue
2549 1 1-
- oat
- 479 posts
- オフライン
I want animate a group of points moving from their original positions based on the vector and velocity values embedded for each of them.
However, I have the following problems:
1. there is always a point at the original position which I don't want.
2. each point will stop after moving for certain distance even if I used a delete node to “kill” it based on its life span.
I'd appreciate your suggestions to solve this two problems!
Thank you!
Thank you!
- oat
- 479 posts
- オフライン
