hello,
maybe this is a simple question, but how do I mix two or more materials (eg concrete with gold 50:50). I'm trying to figure it out 2 hours and nothing.
Previously, I worked in Maya and there it was easy.
thx
Mix two or more materials
17925 17 9-
- cybermax
- 255 posts
- Allegro
- 696 posts
- cybermax
- 255 posts
Allegro
you have to combine the vops together at the vop level unfortunately. Check out the glass material for an example… it combined the old glass and decal materials.
Yes, but I have to copy parameter interface, all vop node and place node multiply, and it is difficult and therefore want to ask if there is any material such as a blendshape node in sop??
- Allegro
- 696 posts
- cybermax
- 255 posts
Allegro
not yet
but it is strange, because I think that mixing (layering) materials is a common task, so I can not understand why this feature is not include Houdini.
- symek
- 1390 posts
- nobodyinparticular
- 73 posts
SYmekcybermaxAllegro
not yet
How any programmable render engines you actually know?
Pixar's Slim shader building toolset for Renderman has the ability to layer multiple appearances (shaders) over each other fairly easily.
just sayin…
- resist or serve -
- wolfwood
- 4348 posts
not yet
Plus with the addition of Co-Shaders a while back ago making a shading pipeline where you can blend ‘looks’ is a lot easier.
- mrice
- 89 posts
I have a material that can blend different surfaces. The idea is that its a layer on top of vops which takes care of the adding/naming/promoting/connecting stuff for you.
link [audenmedia.com]
Lemme know if you have any suggestions
- jimc
- 295 posts
- lisux
- 581 posts
mriceMan this material is really good, probably is the most advanced material I've ever seen for Mantra.
Really good!
Un saludo
Best Regards
Pablo Giménez
Best Regards
Pablo Giménez
- mrice
- 89 posts
- Simon
- 2199 posts
Great work, going to try this out, looks very interesting.
I'd still love to see a simple way to combine 2 or more pre-existing shaders without having to dig around in vops. Been a hobby horse of mine for many years.
Even when you do have the vops available it seems rather annoying to have to then build a whole new shader just to combine them. It would be far more convenient to just wire them into a blend material node and combine them at that level. This is one of those areas in Houdini where a change like that could really help smaller shops and individuals who have less time to write shaders from scratch all the time.
- Soothsayer
- 875 posts
mrice
Hey that's nice work there! The first time I see it.
I have a soft spot for rocks and minerals and there are some effects that ordinary shaders don't handle well or at all (diffraction, polarization, iridescence, double refractions, …). It would be great to have some of those one day.
Jobless
Jobless
- buki
- 1773 posts
Please SESI, put this material into next version!
Awesome stuff Michael!
- Lyonz
- 114 posts
- jrey
- 7 posts
I'm attempting installing this shader in Houdini 11.0.658 under Windows7-64 with no luck. The error msg I get on Houdini startup is
hmaster.exe - Entry Point Not Found
The procedure entry point ??0PI_EditScriptedParams@@QEAA@PEAVOP_Node@@_N1@Z could not be located in the dynamic link library libPI.dll.
I'm guessing something has changed in this math library since Houdini v10 but I'm not sure what I can do about this. has anyone had luck with this shader in v11?
Best regards,
–Jon
Best regards,
–Jon
- francoisd
- 137 posts
