[solved] change width & size of line & particles as
14045 8 3-
- oat
- 479 posts
- rafaels
- 702 posts
Just create a point attribute called “width” and give it a value. That will allow you to do interesting stuff like varying the width of the rendered line along it's length and stuff…
Toronto - ON
- oat
- 479 posts
Thanks, rafaels! that's cool tip!
it seems the “width” point attrib can also affect the size of particles as rendered
pls see the test below with randomized width and size for both the curve and the points …
it's 12am Sat now, I'm just like the image with bits of thoughts irrelevant to each other popping out randomly and my dizzy mind swirling up …… (I'm not high!)
- Ji
- Ji
- edward
- 8104 posts
- oat
- 479 posts
Hi, I installed the latest Houdini 12.0.564 and render the same scene as shown above using the same hip file downloaded from this post, but I get some strange results regarding ambient occlusion rendering.
Pls see the image below which has some bright splotches that are supposed to be dark according to my previous rendering as shown in my previous post.
Pls kindly advise why there's the artifacts.
- Ji
- Ji
- circusmonkey
- 2624 posts
- oat
- 479 posts
- oat
- 479 posts
- Jenny
- 121 posts
