I am trying to port our old rigs, (which were not that hold, just a couple of houdini beta versions old)
and now I see that the flip solver is not attaching assigning an ID
to the particles in the particle fluids.
How can I get that again?
thanks in advance!
Houdini 12 gold Flip slover no particle ID
10458 6 2- diegogarzon
- 17 posts
- jlait
- 6237 posts
- Solitude
- 373 posts
Crossposting here…
http://forums.odforce.net/index.php?/topic/15451-h12-flip-ids/ [forums.odforce.net]
I'm also wondering how to get ids working so that the ids are unique. I've tried a few things, but can't seem to get unique ids out of it. Is there an easy way to get unique ids onto the particles? I understand that turning off reseeding particles is recommended…
The reason I personally like having ids is that it's such an easy way to work with the points/particles post-sim. It makes it much easier to remove unwanted particles for the duration of the simulation. There are also other instances, where you'd want id's post-sim, such as using a copy sop or instancing. Without some unique identifier for each particle, it limits what you can do post-sim without having to resimulate.
Ian Farnsworth
- Solitude
- 373 posts
- mtf
- 16 posts
- johner
- 817 posts
- mtf
- 16 posts
Thanks! I'm really just starting out, so apologies for the basic question, but:
I've clicked to add the attribute id. How do I refer to it in an expression?
Perhaps a better question is, how can I see what attributes are associated with the points so I can know what else is accessible expressions?
Is it $ID?
Is it $ID?
