SCATTER AND NORMALS
   7949   7   0
ANY ONE FACE THIS PROBLEM WITH SCATTER POINT ON SURFACE AND FINALLY END UP WITH WEIRD NORMALL DIRECTIONS
I APPLAY FACET SOP BUT IT DIDENT FIX THE ISSUE
IM ON HOUDINI 12
add vertex normals to you geometry, then shatter it, turn on groups so You get inside geometry group, vertexSOP on that group with Cusp on
PS: Your capslock seems to be stuck
thank you man for replay and sorry for being late
im not trying to shatter it im trying to keep normal position after scattering it
so the points will continue inherit the normal direction from geometry
i try point sop and vertex sop and no one works
ah, damn, wrong read
the geometry You want to scatter on needs pointnormals. scattered points inherit all point attributes
this is a simple poly sphere with normls points
the problem is when i scatter points on the sphere surface i want the new points to inherit the normals ,instead they all point to one direction
points sop or vertex sop or facet sop dosent fix the problem
this is the normals after scattering
works fine here
Rob
rse_scatterNormals.hip (51.2 KB)
Gone fishing
thank you man i move to the new version of houdini and it works fine
