I manually installed new windows update, but after the problem first occurred. And as far as I know I did not touch my graphics driver just before having the problem.
Could a reinstallation of the graphics driver solve the issue ?
So I tried to reinstall the driver, nothing changed.
Also I receive a problem signature when the app crash :
Signature du problème : Nom d’événement de problème: APPCRASH Nom de l’application: houdinifx.exe Version de l’application: 12.5.0.316 Horodatage de l’application: 5140e80f Nom du module par défaut: MSVCR90.dll Version du module par défaut: 9.0.30729.6161 Horodateur du module par défaut: 4dace4e7 Code de l’exception: 40000015 Décalage de l’exception: 0000000000042686 Version du système: 6.1.7601.2.1.0.256.1 Identificateur de paramètres régionaux: 2060 Information supplémentaire n° 1: bb33 Information supplémentaire n° 2: bb33a86ad835fb5d52f50b0336985503 Information supplémentaire n° 3: 13c3 Information supplémentaire n° 4: 13c3baeb5a65df6ee766b4f95dc07811
I manage to solve the problem, the issue was with environment variable. I had HOUDINI_OGL_SOFTWARE = 1 and HOUDINI_UI_QUEUE_SIZE active at the same time and it made the application crash.
Now I only use HOUDINI_OGL_SOFTWARE = 1 because I have the
