I am trying to understand how displacement works in houdini. I applied a worly noise to a simple grid pattern.But i am getting some black artifacts in the surface.I am wondering whats causing this.
Attached the hipnc file here.
Any help would be appreciated.
Thanks !!
artifact in displacement
6325 6 1- Dilesh Lamsal
- 9 posts
- Dilesh Lamsal
- 9 posts
- tomsvfx
- 54 posts
- sanostol
- 575 posts
- old_school
- 2540 posts
With displacements you should also add the Displacement Bounds property.
When rendering, Mantra constructs the geometry within it's natural (non-displaced) bounding box as Mantra doesn't know the extents of the displacement yet when it is dicing the geometry in to micropolygons.
If the geometry is pushed beyond this bounding box when the displacements are applied, the geometry disappears and you end up with holes as you are experiencing here.
By adding the Displacement Bounds render property, you can tell Mantra how much larger to make this bounding box so that when it pushes the micropolygons around, it can still construct the geometry.
Because displacement bounds increases the size of the object, it also increases the amount of memory that Mantra must use so it is important to set Displacement Bounds large enough to capture the displacements but not overly large as to consume too much memory.
- Dilesh Lamsal
- 9 posts
- old_school
- 2540 posts
With Displacement Bounds, you need to set this anyway when utilizing displacements.
As for Full Predicing, this can get around some issues with tearing and displacements but is overkill for most things. It forces mantra to grab a lot of memory up front.
