connectivity sop might help you with that - it will create attribute based on connectivity, then you can group objects. then you can use partition sop to create groups based on that attribute
tmdag connectivity sop might help you with that - it will create attribute based on connectivity, then you can group objects. then you can use partition sop to create groups based on that attribute
or just append Divide SOP directly after your delete1 and check Remove Shared Edges you'll end up with 4 curves representing outlines(open edges) of your 4 separated geometries
