hi
when I emit fluid using a moving object as the source, how to inherit the source velocity accurately ? the only thing i can do now is setting a vel field and apply the field to the emitted fluid but i can't get the result i want.
some tips? thanks
how to inherite the source velocity when emitting fluid
4641 6 1- spoopo
- 19 posts
- old_school
- 2540 posts
- spoopo
- 19 posts
- spoopo
- 19 posts
- old_school
- 2540 posts
Good you got it going. I still have a question.
No velocity at the first frame because there is no velocity at that frame calculated by the Trail SOP? Can you see if the Trail SOP is calculating v at frame 1?
There is the velocity calculation option that defaults to frame forward. Try central difference or backward to current frame and see if that can calculate v at frame 1, if that is the issue.
- goldleaf
- 4164 posts
- spoopo
- 19 posts
im using $FF for the animation , with default setting of the trail sop the velocity is 0 at 1'st frame. when i change to “central difference”or “forward difference” ,i can get the velocity .
And when i uncheck the “evaluate within frame range” ,i can get the velocity as well .
thank you guys so much.
