Hey friends
I am using an object chop to determine the bearing of two objects. I want to convert this data to quaternions in order to avoid gimbal lock.
It seems like it should be obvious, but I can't seem to figure out how to do this in chops.
First I tried to use the qlinear() function with the expression chop, but that resulted in my rotations being zeroed out.
Next I tired to import the data into vops and use the vector to quaternion vop, but I can't seem to figure out how to import the rotation channels into the vop chop.
Your wisdom please!
Quarternions in chops
5250 14 0- GhostCrab
- 27 posts
- edward
- 7720 posts
Where/how/what are you going to use the quaternions for? The best way to do it depends on how you want to use it.
In CHOPs, the euler rotation channels get marked together so that they get be treated as an orientation for better blending where available. So if you're strictly dealing with orientations in CHOPs, there shouldn't be a need to explicitly convert to quaternion.
The qlinear() expression just lets you do quaternion interpolation between the adjoining keyframes, on keyframe channels.
VEX in CHOPs processes one channel at a time, while you need access to all 3 euler rotation channels to generate a quaternion. So yeah, this won't work for sure.
- 8554 posts
It's not always automatic, maybe if you are using Object CHOP to bring rotation channels, but if you are bringing the channels by yourself using Fetch CHOP or creating them in CHOPs directly you need to mark rotation triplets as quaternion yourself using Attribute CHOP so some chops can treat such rotations as quaternions
http://www.sidefx.com/docs/houdini13.0/nodes/chop/attribute [sidefx.com]
- GhostCrab
- 27 posts
Thanks for your input.
Clarification:
I am useing an object CHOP to get the bearing of two objects relative to one another.
I am exporting the bearing rotations to the rotation of an object COP. The current rotations are giving me erratic flipping at the projection poles. Thus I am trying to figure out how to convert those rotations to quaternions in order to avoid gimbal lock.
Thoughts?
Clarification:
Thoughts?
- edward
- 7720 posts
- GhostCrab
- 27 posts
- edward
- 7720 posts
I'm not sure I'd call that a simple .hip file.
The Object CHOP in that case is already using quaternions to rotate the reference's +Z axis such that points at the target object. However, there's no way to specify the up vector for that lookat so I think it's going to be really hard to control the roll of the object this way. So I don't think the flipping is because of gimbal lock, it's probably just that the roll for the orientation is changing. For using quaternions like this, the “roll” will be some “minimal effort” thing that will not be consistent unless you're doing it in very small rotation increments.
It might be better to use the objlookat [sidefx.com] expression to precisely control the upvector. The upvector in this case is well defined anyhow because you have a camera.
PS. It looks like you might be giving the Object CHOP a SOP path? In that case it might be using the identity transform instead of what you expect.
- GhostCrab
- 27 posts
Thanks for your input Edward!
I am not really sure that I understand what you are suggesting.
When I turn off the Look At on the trace object, the object cop itself still produces flipping in the composite menu (when I am in line with the z axis).
Yet it still seems to happen even if I turn off the export flag on my export chop. (bypassing chops, and bearing, entirely)
I get the same sort of flipping either way.
I tried to use objlookat in on the rotation values of my object COP (bypassing chops entirely, and using the recipe in the link you provided). The the expression produced zeros and the flipping remains.
To clarify: the object CHOP is using a reference to parameters on the subnet that contains the “make silhouette” tools. Which in turn are connected an input object and my camera.
How do I attack this?
- edward
- 7720 posts
- GhostCrab
- 27 posts
- edward
- 7720 posts
- GhostCrab
- 27 posts
Thank you Edward for talking me through this. We are making progress.
I simplified the scene and implemented objlookat successfully, things are generally working more fluidly.
Unfortunately I am still getting some unwelcome rotation while looking down the x axis and moving the camera vertically.
Thoughts?
Thoughts?
- edward
- 7720 posts
I don't think you need to do lookat's at all? For the Geometry COP, we want express lumpy's points in the space of the camera. eg. vorigin() expression. In this simple case, rotates are enough so I just used vrorigin() for just the rotates. Then once you trace this, you want to apply the inverse (ie. reverse the arguments to vorigin).
There seems to be strange scaling factor that the Geometry COP applies though so I had to had tweak that in the attached file.
- GhostCrab
- 27 posts
- edward
- 7720 posts
