how to make houdini always use the latest version of otl
   6128   6   2
I got the following message each time I update a DA and save it to a new otl.
Is there a way to configure Houdini to make it always use the latest version of the otl?
Screen Shot 2014-07-06 at 7.53.35 pm.png (26.0 KB)
If you go to Windows->Operator Type Manager, there is a Configuration page. If you turn on the “Give Preference to Definitions with Latest Date” Houdini should always choose the one saved most recently. Without this option I believe it uses the order in which the definitions are found based on the OTL path order.
Mark
thank you very much!
Hi, Mark, I followed your suggestion, but the warning message still pops out whenever 1) I make changes to an otl, 2) change the name of the otl library to which the current otl is saved, and 3) choose “apply”
Is there other option I should consider in the configuration of Operator Type Manager? (see image below)
mtucker
Mark
Screen Shot 2014-10-25 at 4.39.03 pm.png (40.9 KB)
advices are greatly appreciated!
Hope to hear from you experts! Thanks!
when you save a new version of the otl all current instances of that otl will still point to the old one…
use the Object Type Manager to point to the new otl - RMB select Use This Definition.
Training Lead
www.sidefx.com
