Hello.
What is the proper way of deleting fur dynamic simulation (created with “Add Dynamics” shelf tool)?
I deleted AutoDopNetwork node and some time later re-created it (also with the shelf tool), but fur won't simulate.
How to properly delete fur dynamics?
1539 2 0- ajz3d
- 478 posts
- derrick
- 329 posts
The Add Dynamics tool creates a DOP Network (if none exists) and inserts some nodes for the wire simulations. It also adds a couple nodes to the guide hair portion of the Fur Object to fetch the simulation results (a DOP Import SOP and “remove_simulation_attribs” nodes in the Fur Object's contained “guides” network). The only step you appear to be missing is cleaning up the nodes the shelf tool created to fetch the simulation results.
- ajz3d
- 478 posts
derrickI found those nodes and deleting them seems to do the trick. Thank you very much, Derrick.
