Hi, I'm trying to use the HQ Render node but it doesn't even start. It gives me a Warning: Indie does not support generating disk files. an an Error: No command specified for rendering.
It is supposed to render a Mantra node which works fine when rendered manually. Also I'm not using the generate IDF option.
What am I doing wrong :?:
Thanks in advance
HQ Render Indie limitations?
6245 8 2- merlino3d
- 65 posts
- galaxyofterror
- TunaAndAHalf
- 12 posts
- jrockstad
- 11 posts
- jrockstad
- 11 posts
I received a reply from Side Effects Support, stating that there are issues with some machine types on the Amazon EC2 system right now. However, given that this occurs before any information (as far as I know) is sent to the cloud and that some of you are having issues with local render farms as well, I believe this is a Houdini issue and not an Amazon issue.
I'll keep you guys posted.
- TunaAndAHalf
- 12 posts
- VortexVFX
- 33 posts
- Blayken
- VortexVFX
- 33 posts
