Hello
Please, who can explain to me why I can't see the shadow through MPlay? What am I doing wrong?!
Shadow MPlay
1317 2 1- Владимир Пепелов
- 3 posts
- old_school
- 2540 posts
Could be a bunch of things. Instead of chasing all the options, can you post your scene file?
Things to check:
- display vs. render flag on SOPs. Make sure render flag is set to the SOP you wish to render.
- Mantra ROP using candidate objects and omitting your ground plane
Things to check:
- Владимир Пепелов
- 3 posts
Thanks for the response!
Your answer forced me to check the Mantra ROP light settings. I have two lights, area and env. When I left only envlight in Solo Light, I realised the problem is in arealight settings. I tried compare settings of both lights. (why I didn't compare them before?) So, problem was in shadow type. When i change it to Ray-Traced shadow appeared.
Thanks a lot!
Thanks a lot!
