For each Group: What am I doing wrong?
19702 17 4- Soothsayer
- 858 posts
I want to assign a random attribute value to each group, say a color value.
So, I break geometry and get many piece groups.
In ForEach SOP I set Group Mask to piece*
Inside the Foreach SOP I append a color node to the each1 node. In that color node I type: rand(stamp(“../”,“FORVALUE”,0))
but all my pieces have the same color. Where am I going wrong?
Jobless
Jobless
- Allegro
- 696 posts
- stevenong
- 1631 posts
- Soothsayer
- 858 posts
- old_school
- 2540 posts
You could add a detail attribute to the SOP Tree when you are using attribute or group options. No need to use it in the counter method.
Initialize say i ($I) to 0 then do an $I+1 in an Attribute Create SOP. Each iteration will increment your detail attribute.
fyi, detail attributes ride on top of the geometry and you can only have a single entry per attribute. They tend to be very light though.
- Soothsayer
- 858 posts
- old_school
- 2540 posts
First off that first group “inside0” was messing things up a bit so best to use the Group Mask piece* to only process the pieces you want.
The i detail attribute incrementor technique works when you toggle off merge results which makes sense. By not merging the results, you are passing the resulting geometry back through the SOP network and then the $I is incremented and kept. If merge results is off, then the input geometry is sampled fresh for each iteration.
So…
You can use the opdigits() expression on the group parameter reference in to the Each SOP. That will extract the trailing digit which should do what you want while keeping the merge results toggle on.
See the example file for both techniques where I used message (yes it gets annoying real fast) to visualize how the various techniques increment.
Surprising to see that the groups are not processed in order…
So…
- jacob clark
- 665 posts
Hi Sooth,
In regards to the first question. Have a look here.
http://www.sidefx.com/index.php?option=com_forum&Itemid=172&page=viewtopic&t=16047&highlight= [sidefx.com]
cheers,
-j
cheers,
-j
- old_school
- 2540 posts
Nice custom hscript expression Jacob. Yeah use Jacob's method if your groups are not numbered sequentially.
As far as groups being processed randomly anyway, it really doesn't matter in many cases as long as you have a random number generated. Statistically speaking rand() should give you a 50% probability of being above 0.5 and below 0.5.
Ultimately it still would be nice to have your groups sequentially numbered. Bad Maya modelers, bad. lol
- Soothsayer
- 858 posts
- old_school
- 2540 posts
That expression is added to the Each SOP by default when you first place the Foreach SOP.
This expression simply returns the current group being processed as a string.
The first strcmp is used to see if you are using the group option, the second part returns the group name for you.
fortype and forstamp are actually the parameter names on the top ForEach SOP. ../ means go up one directory (which is the ForEach SOP) then fetch the parameter values from fortype and forstamp.
If I want to use the group name specifically, I just RMB on this parm and copy the parm then past relative reference and voila, you get the current group name being processed. I see many users copying the literal expression. No need to that. Just a chs() channel reference to this parm gets you the group name.
- Tom Freitag
- 84 posts
hey,
some years later. Helpful thread. But I have propblem accessing details attribute from last iteration..to sum up my detail attrib at end.
the foreach is driven by attribute value.
for each example(last row is what i want):
iteration detailattrib result (sum every iteration)
1 ————> 5 ———> 5
2. ———–> 3 ———> 8
3. ———–> 2 ———–> 10
4. ———–> 4 ———–>14
My idea: sum=sum(current iteration)+sum(last iteration)
BUT I can't using “MERGE RESULTS” !!
any advice would be great!.
thanks, tom.
1 ————> 5 ———> 5
2. ———–> 3 ———> 8
3. ———–> 2 ———–> 10
4. ———–> 4 ———–>14
thanks, tom.
- 8551 posts
- Tom Freitag
- 84 posts
hey tamte,
big thanks for trying to help
First my fail: I need to CHECK “merge results”, of course.
Since I am working on a tree generator, the most stuff is happening inside the foreach stuff. If I useing feedback-loop, everything is exploding ;(
So I don't have something like a feedback, its only merge every iteration at the end of sops level (like jeff explained above).
I can't look back to my last iteration like stamp(“..”,“FORVALUE”,0) - 1
So I have rebuild my problem i a reayl simple scene, which I have attached.
I tried a lot the last 2 day…but now my brain is bending
thx. tom
thx. tom
- 8551 posts
- Tom Freitag
- 84 posts
tamte, thanks for taking time and replying so fast. Especially from you
i could feel what you mean…to recreate the “merge results” inside a feedback loop. But it seems to be a big change for tiny little problem.
Like I mentioned before its for a treegenerator. Every branch generation I want to happen in a linear fashion, not inside a feedback loop. So one node for every generation to get the unique controll(distribution, shaping) for every iteration/generation.
- 8551 posts
don't worry, it's simple enough
here are 2 methods
1. foreach in feedback mode, processing each iteration the same way as if merge results was on (just geo of the same attrib value), then adding it to accumulated geo from previous iterations and summing the attrib or whatever
2. foreach in merge results mode, but creating additional point per iteration holding your desired data
after foreach splitting the geo and data points, accumulating value of data points as geo detail attrib
here are 2 methods
- Tom Freitag
- 84 posts
