transfering point numbers?
   4119   5   0
hey,
im a bit stuck, should be an easy enough problem to fix though, im trying to transfer point numbers from one grid to another…i created an attribute to collect the point numbers from a group of points of one grid and want to apply them to the other grid so i can control them on that grid…
as always thanks a lot
houdini question.png (247.0 KB)
See attached to match point numbers
scrambled_p.hipnc (64.5 KB)
Gone fishing
interesting node never seen it before…but not exactaly what im looking for, im trying to control what ever points are selected in group1 on grid1 and controlling the same point numbers on grid2..
Why do you need the point number ? , seems kind of irrelevant . See attached for a more complex attack of the problem
scrambled_Cd.hipnc (83.1 KB)
Gone fishing
thanks dave, this is what i was looking for… more tricky then i thought it would be…
the reason i need this technique is because im creating a news ticker. grouping points on a grid and want to transfer the point number onto a tube (to hard to select points on a tube)..
thanks a lot…
Interesting ! . Well without seeing the project I would of thought a interesting solution would be to use the ray sop to project geometry onto a tube . Make your geometry letters with the font sop then project on large tube.
Rob
Gone fishing
