I was working on an Ari tutorial with Houdini 14 a couple weeks ago.
Installed H.15 and wanted to go through the same tutorial again but it calls for dropping down a Geometry Node of which I cannot see/find in Houdini 15.
Is there an equivalent to a Geometry node or is it now under a new name?
Geometry Node gone in Houdini 15
2750 6 2- BabaJ
- 2042 posts
- anon_user_89151269
- 1755 posts
- BabaJ
- 2042 posts
- BabaJ
- 2042 posts
ok so it does….
what happened is that I had a sphere and was in that sphere…deleted the sphere but didn't realize I had only deleted its sub-node.
So in that case geometry node is not available at that level.
going up one level to actually delete the whole sphere solved the problem.
sorry for creating any confusion.
- danBode
- 50 posts
- old_school
- 2540 posts
I really like the Houdini acronyms. So what for Houdini speak naysayers. It rocks.
If it were me I'd say “add a Geo Object” which means go to /obj and tab geo.
What's a Geo node? Object Geo container node? Geometry ROP? Not a SOP… It's ambiguous.
As for SOPs, if you are adding SOPs I say SOPs.
After a couple days you know Objects, SOPs, DOPs, ROPs.
Rant out.
Rant out.
- BabaJ
- 2042 posts
