Motion blur incorrect
4796 7 2-
- julca
- 271 posts
- Enivob
- 2658 posts
- trojan_goat
- 41 posts
- jason_iversen
- 13004 posts
It's common for forwardly extrapolated motion blur to overshoot when a motion discontinuity like this happens (hitting the bottom of the bowl) and so you might try adjusting your Shutter Offset.
- julca
- 271 posts
Hello all, Thanks for your comments.
I directly import my simulation files “*.bgeo.sc” without scaling.
But when I build my simulation I scale some parameters like Gravity force (-980.665) and Spacial Space (0.01) and Mass Scale (0.01).
That's because I scale my collider object by 100 to allow me to use a small emitter (start to fill a barrel of 600L with an emitter of 3cm diameter).
And I try to play with the Shutter Offset but without succes (just reduce this problem but dont resolve it entirely).
The fact is my liquid fall quickly and if I reduce my velocity parameter (ex. by 0.1) I don't have enough blur.
Can you tell me where I'm wrong ?
I've joined my project with the first 25 frames simulation cached files.
Thanks.
Thanks.
- JordanWalsh
- 145 posts
- julca
- 271 posts
- julca
- 271 posts
Just to conclude,
I need to clamp my velocity vector length instead of clamp individually my velocity vector components (x, y, z) individually like I do in the attribute VOP screenshot of my last post
ops: .
In order to not change velocity direction.
To polish more :idea: I compute the distance from each liquid point to the collision object (use the velocity for direction) and determine the lower velocity length limit (cf. screenshot).
ops: .In order to not change velocity direction.
