There is a Box inside my Sphere
2979 11 2- MagnusL3D
- 1104 posts
As you can see on the attached image, I have highlighted a box which is inside a sphere, and also there is a tube going through the sphere.
How would I procedurally remove the box and keep the sphere and cylinder ?
Houdini file attached.
EDIT: Came to the conclusion that you can assume that the sphere is in a group, so I have updated the example file to better reflect the situation.
Edited by - Dec. 7, 2015 16:08:25
- BabaJ
- 2048 posts
- MagnusL3D
- 1104 posts
BabaJ
You can click on the boxes bypass flag ( it's the furthest flag on the left of the box object - bypass flag turns yellow when it is on )
Ofcourse, but that's not very procedural. I want to detect any loose geo inside the sphere and delete it. This is a simplified setup to illustrate what I want todo.
- BabaJ
- 2048 posts
Instead of deleting it…maybe do something like create a group node between merge and sphere and one between merge and cylinder….then whatever you do after merge only use( select ) the names of the two groups…whatever may be “loose geo” won't be included…effectively deleting it.
If you have a complex process in which you not sure where the “loose geo” is coming from, maybe retrace your steps back to the beginning and for each node have a look at the spreedsheet to see what it getting generated…then maybe you can figure out a way to sort your process with the use of other nodes like maybe the group node for example.
- MagnusL3D
- 1104 posts
BabaJ
If it was this simple I would not have asked the question. And it can't be backtraced to earlier in the graph. I am searching for a way to identify lose geo inside other geo without any previous indications such as a group.
- BabaJ
- 2048 posts
- MagnusL3D
- 1104 posts
BabaJ
Perhaps you could provide more details of what the situation is?
Actually come to think of it, you could assume one thing, that the sphere is in a group. I've added that to the test scene here.
Perhaps that will help.
Think of it as forLoop clipping over a split up mesh, which is then merged with the sphere and you need to remove things that are entierly inside the sphere, but not the ones sticking out.
- BabaJ
- 2048 posts
There is a bounding box option on the group node and it also has a sub-option for points only.
I tried playing around with it…along with add and resample nodes ( to try and work with points only ) and didn't have any luck.
I suspect it would be a combination of those nodes along with some of the nodes in the modily shelf like “copy to points” , “combine”, etc.
sorry…couldn't help.
- MagnusL3D
- 1104 posts
BabaJ
Well that's allright. thank you for trying. I should perhaps say I already have a working solution. I was just curious to see if there is a better solution than mine.
- MagnusL3D
- 1104 posts
- MikePaixao
- 36 posts
- MagnusL3D
- 1104 posts
