I'm trying to build a displacement shader that is scaled dependent on a point attribute. So I import the variable in my material and plug it into the displacements scale. However I somehow do not get smooth normals with the shadingNormal node, resulting in ugly edges like you can see in the picture.
Do you have any ideas how to fix that?
Thanks in Advance!
displacement normal problem
2183 4 1- steff
- 25 posts
- 8583 posts
that's because your attribute is interpolated linearly within the polygon, so while your normal may be correct, the faceted look is actual shape of displaced mesh
to get smooth interpolation within polygons, you'd probably need to render your object with Render Polygons As Subdivision checked
- steff
- 25 posts
thanks! yep the displacement itself is how i like it to be. i just thought that shadernormal would interpolate normals within the facets as the shader iterates over all surface intersections!?
unfortunately checking ‘render polys as subdivisions’ does not solve it. The displacement disappears entirely…
asinus humanum est
- 8583 posts
steffit does that, however the facets are diced for displacement to around pixel size so if your displacement results in flat plane, the normals will be flat, which is correct
… i just thought that shadernormal would interpolate normals within the facets…
steff
make sure you normalize the N before plugging to displacenml1
or just disconnect it completely
- steff
- 25 posts
