OpenCL sim will not playback.
2447 10 0- Noboru_Garcia
- 75 posts
Any tips on rendering out Open CL fluids to disk? The file sizes of the cashed frames are all various sizes that are the correct size for a 1,000,000 particle sim. The card makes it all the way through but the playback does not move at all when I load itinto the playback. CPU renders work fine. 680 Gtx with 4 gigs of ram. The sim only used 800 mb of going memory while computing.
- “spooky action at a distance”. Albert Einstein
- Enivob
- 2558 posts
- Noboru_Garcia
- 75 posts
I use the default.
$HIP/sim/$HIPNAME.`opname(“..”)`.$SF.sim
It writes the files out and when I open the sim with a DOP network using playback simulation as “show sequence as one entry”. It will properly load the sim for whatever frame I am at. When I change frames though, the fluid sim does not update. The sim appears to be stuck on the one frame.
- anon_user_37409885
- 4189 posts
- Noboru_Garcia
- 75 posts
- 4189 posts
- Noboru_Garcia
- 75 posts
Yes. Sorry. I get correct fluid with CPU. Once I check the OpenCL on the solver the fluid just lands on the ground as it it was stick on collision, with no interaction with itself.
Reading any cashed fluid sim on OpenCL results in instability and Houdini crashes if I delete a DOP solver reading the sim. You
- 4189 posts
- Noboru_Garcia
- 75 posts
- 4189 posts
- Noboru_Garcia
- 75 posts
