I need to create a custom node (digital asset?) in Houdini. It should include multiple Xform SOPs connected one after the other but it's count will varry. This is useful to move individual shapes in an Alembic SOP to different positions by using a single node, other than connecting Xform nodes in chain. Any help?
Joj
Custom node in Houdini containing multiple Xform nodes
4150 7 3- jojanpm
- 22 posts
- grayOlorin
- 1799 posts
if you need the contents of your digital asset to change, you can add a subnet under your asset, and when generating a digital asset (under the nodes tab), make your subnet editable. That would allow a python module embedded on your digital asset to simply generate xform nodes under your digital asset
if you are bringing all your shapes from an alembic node, however, you can also go the route of using a single alembic SOP node to bring all your shapes in as packed primitives, then simply use a primitive VOP or Wrangle node to transform each packed prim in parallel (MUCH more efficient as it is SIMD)
-G
- jojanpm
- 22 posts
- grayOlorin
- 1799 posts
here it an example using a VOP. It does not have to be a wrangle, the point is that if you are passing packed prims or alembic packed prims, you should be able to process each packed object in parallel.
I did forget to mention that you do indeed need to store your transformation as an attribute then use either a primitive SOP or a point VOP to transform it as you cannot change primitive positions in VOPs (at least that I know…)
Here is an example using a copy SOP to generate a collection of packed prims. I did not have an alembic to show you, but if you are importing your objects as Delayed Load primitives, this should work the same
-G
- jojanpm
- 22 posts
- matthias_k
- 483 posts
Do you mean a combined move?
Example shows a multiparam cumulative move…
You can use something similar to add individual moves
to given alembic parts, if you extend the “My Move” with a Group Input
field…
Maybe I've misunderstood your idea totally, then simply ignore it.
field…
Edited by matthias_k - Aug. 8, 2016 02:48:08
- grayOlorin
- 1799 posts
hey jojanpm, yes. Assuming your transformations are stored by attribute (on a per primitive basis) you can either
a- use a point vop/wrangle instead of a prim vop, and use the prim num to fetch the transformation attribute, then apply it to the points in one shot
b - if they are attributes, you can also simply use the primitive SOP that I have in my example without having to even use a VOP/wrangle
where does your transformation come from?
-G
- jojanpm
- 22 posts
