Hi there , I'm trying to recreate a setup I have in Softimage ice which controls seats in a football stadium. i have around 5000 to 10000 seats instanced on a grid fliping down as a falloff object passes over them.
I am basically doing a linear interpolation between 0-90 based on per point blend value
I have a similar setup in Houdini with the copy sop which works great but obviously is very slow with only a fraction of the amount of seats
so I have been attempting to use the instance node and rotate the points directly with VOPs but not having much success.
would this be the correct approach for something like this? i have attached my copy SOP scene which is the behavior i'm after but I want instances!
Very new to Houdini so any pointers would be much appreciated
Sam
instance geo and rotate points with VOPS
4815 4 0- samboyd
- 5 posts
- Enivob
- 2539 posts
Hi Sam,
Here is a link to a file that demonstrates how to use Instancing like the Copy SOP. Instancing is faster so you probably want to go that route with your stadium.
http://forums.odforce.net/topic/23294-houdini-16-wishlist/?do=findComment&comment=143811 [forums.odforce.net]
Here is links page to other example files on the OdForum.
http://forums.odforce.net/topic/25173-atoms-link-page/ [forums.odforce.net]
Also check out Tokeru, there are a lot of example files there as well.
http://www.tokeru.com/cgwiki/?title=Houdini [tokeru.com]
Using Houdini Indie 20.0
nVidia 3050RTX 8BG RAM.
- samboyd
- 5 posts
- mestela
- 1743 posts
- samboyd
- 5 posts
