From a C4d background. The image is a very basic level of what we would use xpresso for. In this example the rotation of the handle is asked to operate the position of the sphere. But not just a copy/past of relative reference, but a range from the handle rotation that is converted to a different range on the Sphere's position.
Can this sort of thing be done with VOP, or another visual network in Houdini? Are channel expressions my only option?
VOP SOP maybe?
2834 11 1- tranasaurus
- 43 posts
- sepu
- 420 posts
- tranasaurus
- 43 posts
- Jim Rutherford
- 67 posts
- peteski
- 517 posts
Hey I was a bit bored so I mashed something together. I reckon this task would have to be way more suited for chops but I have no idea how to use that (other than adding noise and stuff)…
Hopefully this is what you were after! I am just animating a single point with an attribute VOP then creating an expression on the transform of the box that gets the position to that animated point.
Just grab the handle and rotate. There are exposed max/min parameters on the att vop.
Anyway, there's probably a better way but maybe posting this up here will horify someone enough that they post a better solution
Pete
Pete
- peteski
- 517 posts
- tranasaurus
- 43 posts
- peteski
- 517 posts
- tranasaurus
- 43 posts
- peteski
- 517 posts
Oh that sounds cool! I'm holding off looking at that… Saving it up till the launch next week
It would be nice if they make it a little easier to bring object references into vops. It still feels a little awkward for me moving things into other contexts.
The way I set this scene up was to first make a parameter in vops, then copy the rotation channel reference into it. it'd be nice if there you could just drag the reference in like this.
P.
P.
- tranasaurus
- 43 posts
That would be nice. Judging from the ICETree, I'm guessing you are from SoftImage decent? I never had the pleasure of trying that software out. My background is mostly C4d and Modo. Did a bit in MAX, but it didn't stick.
Your profile says that your from Australia. I just lost my last two weeks of sleep watching the Open.
- peteski
- 517 posts
