I am trying to follow along on the Houdini 16 Masterclass | Hair & Fur
https://vimeo.com/207704687 [vimeo.com]
I am trying to follow along but cannot find out how to use the attribute wrangle and paint the areas for the eyebrows, beard, short skin, etc. Do you have a copy of the head with groom file so I can reverse engineer it?
I don't even need the head file, if that is proprietary, just a model that shows how to select the geometry on the head and use it for the they “EYEBROWS_OUT” null. Or if any one else can help point me in that direction, that would be helpful.
Hair Masterclass files?
14469 24 5-
- bakerstudent
- 14 posts
- bakerstudent
- 14 posts
- KaiStavginski
- 665 posts
- bakerstudent
- 14 posts
- KaiStavginski
- 665 posts
- bakerstudent
- 14 posts
- goldfarb
- 3465 posts
- KaiStavginski
- 665 posts
- goldfarb
- 3465 posts
- bakerstudent
- 14 posts
- Goddy McRoodt
- 35 posts
- bakerstudent
- 14 posts
- KaiStavginski
- 665 posts
- bakerstudent
- 14 posts
- 3d-gang
- 12 posts
- martinkindl83
- 287 posts
- KaiStavginski
- 665 posts
No problem - here's that rubbertoy scene.
I disabled some file caches to makes sure there are no external dependencies.
You should run the two File Cache SOPs in /obj/blob_geo/sim. These are for the FEM simulation and for generating the deforming collision VDB.
Kai Stavginski
Senior Technical Director
- martinkindl83
- 287 posts
KaiStavginski
thank you very much, thats exactly what i was looking for.
- 3d-gang
- 12 posts
KaiStavginski
Thank you Kai, it helped a lot.
- abvfx
- 71 posts
Goddy McRoodt
stupid question,
where do i set the “display density” instead of showing the full final render denstity? I have a lion that is not kind to the viewport with all hairs on
I would also like to know where i can adjust the density just for the viewport.
Senior Groom TD @ Industrial Light & Magic - abvfx [abvfx.me]
