since there aren't too many extensive tutorials on Houdini (especially newer versions), I decided that I would follow Rohan Dalvi's series and just learn along the way.
Since I'm only just starting with the tutorial, I wonder if it's okay to keep this thread as a general thread for any questions that are related to this tutorial series and changes to Houdini 16.
Now I already figured out that Rohan is using an older group node that is obsolete and should not be used anymore, but I can't really figure out what node to use and how to get the same effect. It's very simple, I basically need to create the settings as seen in the attachment. (Create a Group with “top” as Group Name, Points as Entity and a Pattern of 1.)
Thank you for any help, and excuse me for asking such a simple question.
Rohan Dalvi - Rocketship Tutorial in Houdini 16 (and the Group Node)
7203 11 3- Gilgamesh
- 4 posts
- BabaJ
- 2048 posts
- Gilgamesh
- 4 posts
- electricalpencil
- 149 posts
All the group node is doing in Rohan's example is selecting point # 1, and naming it top. In h16 if you drop the new group node you'll see a base group field, you can type 1 there (and change group type to points), and it will do the same thing as the old group.
Another tip, anytime you drop a node and it lets you choose a group, usually at the top, you can enter a pattern directly, pattern is just the points/primitives numbers, ie type “1-10” and houdini will automatically create a group base on the group type.
- Gilgamesh
- 4 posts
- Alfheimr
Hi there.
Guys i'm total noob, I've just started to follow some tutorials.
I have this problem with the new group node in houdini 16.
How can i use this “filter expression” in H16 ? please help
when i write “rand($PT) > 0.5” in group node / base group it doesn't work.
It's not working in “group expression” too
I could not find any answer in google.
This is a screenshot from tutorial.
http://imgur.com/a/HVJ59 [imgur.com]
Edited by Alfheimr - March 17, 2017 12:40:22
- neil_math_comp
- 1743 posts
Group Expression uses VEX, instead of HScript and local variables.
rand(@ptnum) > 0.5
seems to work.
Edited by neil_math_comp - March 17, 2017 13:10:40
- Alfheimr
- mikeyleo
- 5 posts
I working on the rocket ship tutorial and I'm stuck on the section where the cable is created. I'm trying to create a group that contains the first and last points of a line. In the tutorial, Rohan uses 0 and $N. The 0 works, but the $N doesn't. I've tried points(0)-1, but that didn't work either. Has anyone been able to figure this part out?
Thanks.
Thanks.
- neil_math_comp
- 1743 posts
With Group Expression:
Alternatively, with a regular Group field, or with the Base Group field on the Group Create SOP:
@ptnum == 0 || @ptnum == npoints(0)-1
0 `npoints(0)-1`
Edited by neil_math_comp - April 18, 2017 01:08:29
- mikeyleo
- 5 posts
- anon_user_37409885
- 4189 posts
