Error code?
   8772   5   0
Does anyone know what this means?
It keeps popping up in my Houdini Dialog Box.
WARNING: OPUI_DialogPRM2: Symbol “open.val” value stepped on.
Qt Warn: External WM_DESTROY received for QWidgetWindow(0x205c294f760, name=“RE_WindowWindow”) , parent: QWindow(0x0) , transient parent: QWindow(0x0)
Qt Warn: External WM_DESTROY received for QWidgetWindow(0x205c294da80, name=“RE_WindowWindow”) , parent: QWindow(0x0) , transient parent: QWindow(0x0)
Qt Warn: External WM_DESTROY received for QWidgetWindow(0x205c294dfc0, name=“RE_WindowWindow”) , parent: QWindow(0x0) , transient parent: QWindow(0x0)
Qt Warn: External WM_DESTROY received for QWidgetWindow(0x205c294ece0, name=“RE_WindowWindow”) , parent: QWindow(0x0) , transient parent: QWindow(0x0)
Qt Warn: External WM_DESTROY received for QWidgetWindow(0x205c1bbca00, name=“RE_WindowWindow”) , parent: QWindow(0x0) , transient parent: QWindow(0x0)
Qt Warn: External WM_DESTROY received for QWidgetWindow(0x205918bd480, name=“RE_WindowWindow”) , parent: QWindow(0x0) , transient parent: QWindow(0x0)
Qt Warn: External WM_DESTROY received for QWidgetWindow(0x205c286ef20, name=“RE_WindowWindow”) , parent: QWindow(0x0) , transient parent: QWindow(0x0)
Qt Warn: External WM_DESTROY received for QWidgetWindow(0x205918bcd00, name=“RE_WindowWindow”) , parent: QWindow(0x0) , transient parent: QWindow(0x0)
Qt Warn: External WM_DESTROY received for QWidgetWindow(0x205c8912140, name=“RE_WindowWindow”) , parent: QWindow(0x0) , transient parent: QWindow(0x0)
Qt Warn: External WM_DESTROY received for QWidgetWindow(0x2058f6a3340, name=“RE_WindowWindow”) , parent: QWindow(0x0) , transient parent: QWindow(0x0)
Qt Warn: External WM_DESTROY received for QWidgetWindow(0x205c89120e0, name=“RE_WindowWindow”) , parent: QWindow(0x0) , transient parent: QWindow(0x0)
Qt Warn: External WM_DESTROY received for QWidgetWindow(0x2058f6a3880, name=“RE_WindowWindow”) , parent: QWindow(0x0) , transient parent: QWindow(0x0)
Qt Warn: External WM_DESTROY received for QWidgetWindow(0x205a183e080, name=“RE_WindowWindow”) , parent: QWindow(0x0) , transient parent: QWindow(0x0)
Qt Warn: External WM_DESTROY received for QWidgetWindow(0x205a183eb60, name=“RE_WindowWindow”) , parent: QWindow(0x0) , transient parent: QWindow(0x0)
Qt Warn: External WM_DESTROY received for QWidgetWindow(0x205a183dd80, name=“RE_WindowWindow”) , parent: QWindow(0x0) , transient parent: QWindow(0x0)
Qt Warn: External WM_DESTROY received for QWidgetWindow(0x20599bbb940, name=“RE_WindowWindow”) , parent: QWindow(0x0) , transient parent: QWindow(0x0)
Qt Warn: External WM_DESTROY received for QWidgetWindow(0x205a959f640, name=“RE_WindowWindow”) , parent: QWindow(0x0) , transient parent: QWindow(0x0)
Qt Warn: External WM_DESTROY received for QWidgetWindow(0x205a959d480, name=“RE_WindowWindow”) , parent: QWindow(0x0) , transient parent: QWindow(0x0)
Qt Warn: External WM_DESTROY received for QWidgetWindow(0x205a943ffa0, name=“RE_WindowWindow”) , parent: QWindow(0x0) , transient parent: QWindow(0x0)
Qt Warn: External WM_DESTROY received for QWidgetWindow(0x205a9771360, name=“RE_WindowWindow”) , parent: QWindow(0x0) , transient parent: QWindow(0x0)
*** OCTANE API MSG: Tried to access null node
*** OCTANE API MSG: Tried to access null node pin
Reel Inpsirations
Houdini Work in Progress [vimeo.com]
It looks like you may be opening a HIP file that was created on a system that has the Octane renderer. Your system may not have Octane, however. Typically warnings can be dismissed, errors need to be resolved.
Using Houdini Indie 20.5
nVidia 3060RTX 12BG RAM.
I've got the same warnings and yes, I do have installed a GPU render and it's Redshift.
Stumbled upon the same thing today and it's not related to any external renderer in my case.
Seems like Houdini has a problem with (spare) parameters with the name “open”.
Creating a spare parm with that name produces the same warning and the parameter pane for that node stops updating correctly ( when creating keys, deleting channels etc ).
Edited by blackpixel - Oct. 6, 2017 09:11:34
I've been running into this issue a lot! It seems to happen when I have an Octane a material that is using a custom parameter from inside the nodes. In my case, I had a RGB color node I wanted to control form the “shop level” of that material. I feel like Octane for Houdini is causing a lot more crashes than a professional render engine should cause!
Anyone have found a fix for this!
I have been learning houdini indie and get this a lot. I have been getting it randomly. I just started a scene with particles and got it while in the POP network.
