I'm trying to use an image sequence in a Surface Color VOP and it's only loading the first image ( img.0001.exr ) not the current frame $F4
I noticed when I try the texture seq in the Surface Textures tab of a principled shader it works fine.
I tried loading it first to cops, then reference it with op: syntax, same story.
If this is a bug, any work around I can use in the meantime ?
I'm using 16.0.541
Image sequence Surface Color
2482 5 2- A-OC
- 253 posts
- 7814 posts
It's not a bug, time dependent expressions are not supported in vex, without using a parameter to pass the evaluation to the shader. Promoting the filepath input of the surface color node, and placing the expression on the parameter will work, but the parameter needs a level above to exist in order to evaluate. Meaning the parameter node must be inside a material builder for the animated value to evaluate.
I'm not sure why the op referenced composite image didn't work, but it seems to have the same limitations, parameter node in a material builder only.
- A-OC
- 253 posts
- 7814 posts
Unfortunately, it doesn't seem possible. The parameter with the animated value has to be in the outermost material builder. A work around, would be to store the attribute on your geometry. If your geometry is animated, you could store the texture path for the current frame as detail or primitive attribute.
- A-OC
- 253 posts
- papsphilip
- 385 posts
jsmack
I ve been looking for an answer to this but i dont quite understand what you are saying. can you provide an example?
i have a primitive string attribute with the filepath including the expression $f3 etc and i plug that attribute to a material node to override base color texture but it doesnt work. The material node points to a principled shader
