yjyoung
Lurker
I have not much experimented with mcbiovision yet but basically what I did was just run it get .cmd and bclip files. Once you have those files, run Houdini and you can either open text port and run “source” command to run the script file(eg, ->source run.cmd) or go to file and select “Run Script” then select your .cmd file. After you run the script, go to chop then add a file operator then open your .bclip file then export. now all the bones should be mapped to channels you brought from .bclip file.
I'm not sure exactly what they mean by “export” I know how to add a file operator, but how do you export from the file operator? And what do you export to….
Any help would be appreciated.
