Curve From 2 Views
   2017   4   3
I'm trying to make something similar to the Crv2View command in Rhino.
So I have this polygon curve:
And I want to move each point straight down in Y axis to line up with a NURBS curve, like so:
So I need to somehow find out what the Y position is on the NURBS curve at the appropriate X position. Basically I need to translate this pseudo-code into VEX:
foreach(Curve1.point) {
Curve1.point.yposition = getYposition(Curve2, Curve1.point.xposition);
Alas, I'm VEX-impaired so any help would be greatly appreciated.
Thanks.
top view rs.png (31.0 KB)
illustration rs.png (42.0 KB)
Try using a polygon curve, then if you really need a NURBS curve, you can use a Fit SOP with Method set to Interpolation to convert it to a NURBS curve going through those points after you have the points set up as you'd like them. The VEX code for setting the coordinates should be _much_ easier with a polygon curve than with a NURBS curve. Hopefully that approach works for what you need.
You could transfer the height of your side view curve to colors and flatten it.
@Cd = @P.y;
@P.y = 0;
Then let your top view curve shoot rays on the flattened side curve asking for the color to use it as its new height.
vector pos;
vector uv;
intersect(1, @P, {0,0,1}, pos, uv);
@P.y = primuv(1, "Cd", 0, uv);
curve_from_2_views.hipnc (94.0 KB)
Konstantin Magnus
@Cd = @P.y;
@P.y = 0;
vector pos;
vector uv;
Works like a charm. Big thanks to both of you. Much appreciated.
On a related note, I don't suppose there's a way to visualize the rays sent by intersect, sort like point trails?
jacksprophet
Sure, intersect() returns the hit position, as well. Subtracting pos and the current point position @P right after it should show you the rays, eg:
vector pos;
vector uv;
v@ray = pos - @P;
//@P.y = primuv(1, "Cd", 0, uv);
It kind of overshoots when you turn the visualization button on, though. Dont know why.
