Blend shape and material ?
   4092   9   1
Hello I need to know how to use blendshape with a texture, here I have a selection on my mesh just on the eyes that stays white, if I activate the blendshape node the selection does not pass anymore. What is the solution to be able to make my blend keeping my polygon salt and texture on it? Thank you
Capture d’écran 2018-01-26 à 13.21.39.png (1.1 MB)
Capture d’écran 2018-01-26 à 13.21.07.png (1.2 MB)
Sorry for my english but i learn too ^^
1 ryzen 3970X 64go
1 xeon hexacore 32go
1 i7 hexacore 16o
There is a checkbox on the Blendshape node for transferring other attributes. Have you checked them? The material would need to exist before you connect to Blendshape.
Edited by Enivob - Jan. 26, 2018 09:02:53
Using Houdini Indie 20.5
nVidia 3060RTX 12BG RAM.
i dont have this chek box ?
Capture d’écran 2018-01-26 à 15.11.57.png (63.0 KB)
1 ryzen 3970X 64go
1 i7 hexacore 16o
Those are the checkboxes I was mentioning.
You still have to put your materials “in-line” before you get to the BlendShapes node, or the @shop_materialpath attribute won't exist.
Edited by Enivob - Jan. 26, 2018 10:32:29
Im sorry but i dont understand what is in line ? is this ?
Edited by bgood - Jan. 26, 2018 11:07:35
Capture d’écran 2018-01-26 à 17.06.27.png (213.6 KB)
1 ryzen 3970X 64go
1 i7 hexacore 16o
you could also do this
Training Lead
www.sidefx.com
ok !
1 ryzen 3970X 64go
1 i7 hexacore 16o
@arctor: But if you do it that way the materials won't blend, right?
Enivob
You can't blend materials. A material is a string (node path), it doesn't make sense to have an in between value.
But if the material has a texture, UV coordinates can be blended. You would still want to assign materials before the BlendShapes, not after it.
