Hi
Like the title says I'm trying to match point numbers between geometry with exactly the same topology (however point numbers are in diffrent order which breaks down the animation that I'm working on). I've created and attribute and assigned point numbers of first geo to this attribute, then I've tried to use sort SOP “by attribute” option on the second geometry match the point numbers but it didn't work, the sort node change the numbers a bit but they didn't match. For some reason when I use the attribute transfer node it works for the 10 first frames of the animation and then it breaks down. Attribute copy doesn't work. I attach exaple hip file, hopes this helps to understand what I'm trying to achieve, Any help would be reatly appreciated!
Matching point numbers between geo with the same topology
1805 2 0- Hubert-Blajer
- 8 posts
- 8555 posts
- Hubert-Blajer
- 8 posts
