i developed a serie of python scripts which manage node(s) comment and add “documentation to comment” functionality.
When learning Houdini it may be hard to undestand the flow of nodes and to take a sneak peak on the purpose of a single node: a user has to select right click on node -> help and wait for Houdini internal browser to load the help page.
These scripts simplify this operations letting user automatically/manually populate node comment with proper text.
RIGHT MOUSE BUTTON MENU VOICES ON NODE:
- Use help as comment: populate node/selected nodes comment with online documentation headline
- Use help as comment for children: populate node/selected nodes and its/theri children notes comment with online documentation headline
- Display node comment: make node/selected nodes comment visible
- Hide node comment: hides node/selected nodes comment
- Remove node comment: removes node/selected nodes comment
- Display children comments: make children nodes of node/selected nodes comment visible
- Hide children comments: hides children nodes of node/selected nodes comment
- Remove children comments: removes children nodes of node/selected nodes comment
NOTES:
- Scripts work when selecting a single node and with multiple nodes
- Some nodes don't have headline or the whole documentation file.
- Script should work on every OS due to OS path separator code, if fails fix/report please.
- Scripts are separated for studying and modifying.
TESTED VERSION/S: HOUDINI 16.0/16.5
REPO: Help 2 comment Suite… [github.com]
Hope will help some users.
