Help 2 Comment Suite : a serie of free scripts to populate node comment with documentation headline
   613   0   1
Hi all,
i developed a serie of python scripts which manage node(s) comment and add “documentation to comment” functionality.
When learning Houdini it may be hard to undestand the flow of nodes and to take a sneak peak on the purpose of a single node: a user has to select right click on node -> help and wait for Houdini internal browser to load the help page.
These scripts simplify this operations letting user automatically/manually populate node comment with proper text.
RIGHT MOUSE BUTTON MENU VOICES ON NODE:
  1. Use help as comment: populate node/selected nodes comment with online documentation headline
  2. Use help as comment for children: populate node/selected nodes and its/theri children notes comment with online documentation headline
  3. Display node comment: make node/selected nodes comment visible
  4. Hide node comment: hides node/selected nodes comment
  5. Remove node comment: removes node/selected nodes comment
  6. Display children comments: make children nodes of node/selected nodes comment visible
  7. Hide children comments: hides children nodes of node/selected nodes comment
  8. Remove children comments: removes children nodes of node/selected nodes comment
NOTES:
  • Scripts work when selecting a single node and with multiple nodes
  • Some nodes don't have headline or the whole documentation file.
  • Script should work on every OS due to OS path separator code, if fails fix/report please.
  • Scripts are separated for studying and modifying.
TESTED VERSION/S: HOUDINI 16.0/16.5
REPO: Help 2 comment Suite… [github.com]
Hope will help some users.
Edited by Neogene79 - May 9, 2018 06:00:12
