i cant find Cluster tab in Vorooni Fracture sop . is there any trick to use it ? for example i want to use tiledbox to make brick pattern from this tutorial :
http://www.tokeru.com/cgwiki/?title=Houdini#Voronoi_cluster_and_fracture [www.tokeru.com]
but there is no cluster tab in vorooni fracture in houdini 17 , is there any new trick to do it ?
tnx
where is Cluster tab in Vorooni Fracture sop ?
14992 10 1-
- vrman
- 39 posts
- cwhite
- 792 posts
- vrman
- 39 posts
- JulianAbreu
- howiem
- 146 posts
Yup - a little frustrating that the old Voronoi Frac SOP has been replaced like this. I don't do much RBD stuff but use the Voronoi Frac SOP for lots of other stuff so it makes me a little nervous having to start dropping nodes with “RBD” in their name in
You can use a textport to add the old one in manually, though. Make sure you're in the right network first:
/ -> cd /obj/geo1
and then add the node with the -e flag (this makes opadd use the name as given, rather than using any later versions):
/obj/geo1 -> opadd -e voronoifracture
/ -> cd /obj/geo1
- JulianAbreu
I think I got it,
place the Voronoi node, and select copy cell point to attribute, and in points type “cluster” which is the one made by the cluster node before or by you if you're doing it manually.
connect the new RBD cluster Node and you already
have the clusters
To make it work in the SIM, when using the Assamble node you got to uncheck “Create Name Attribute” so It can pick up the “cluster” attribute and looks like it works.
have the clusters
Edited by JulianAbreu - Dec. 6, 2018 01:53:28
Julian Abreu Student at Urbe, Venezuela
- Hendrik Voßkamp
- 4 posts
- Kijas
- cwhite
- 792 posts
https://vimeo.com/332035825 [vimeo.com] has lots of details. For colouring you can use the visualizer action button, or use the Color SOP's Random from Attribute option if you need an actual Cd attribute
- 5DN
- 152 posts
- gzgtwz
