Hi.
I'm trying to connect random points and make polyline by using near point function with iterations.
but, I can't.
This pic is my script.
Could you give me advice?
How to connect random points
2560 4 0- kazurati
- 27 posts
- Dave_ah
- 436 posts
- kazurati
- 27 posts
- Dave_ah
- 436 posts
Turn on DISPLAY POINT NUMBERS in right column of scene view. Then enter those numbers into ADD SOP. I think, you can also preselect them in desired order then drop an ADD SOP node via TAB inside scene view. Press ENTER, and ADD SOP should now have point list with toggle switch for Closed/Open. If you opt for CLOSED, Houdini will create a poly out of those points. If left OPEN, you'll get a polyline.
- BabaJ
- 2042 posts
