in houdini,
how to draw a nurbs curve directly on a nurbs surface without using project/ray SOP? is it possible?
thx
draw on nurbs surface
7764 6 1- metaclay
- 122 posts
- wolfwood
- 4262 posts
- stu
- 246 posts
- metaclay
- 122 posts
- wolfwood
- 4262 posts
metaclay
thanx,
the only problem that it only snap the points , means if i draw the nurbs curve on a sphere, then the points of the curve is on the sphere's surface , but the curve itself cannot really stick on the surface.
or did i miss something?
Yes it will only snap the points, if you need to curve to fit exactly on the surface then you'll need to use more samples (points) to create the curve.
- VisualCortexLab
- 509 posts
metaclay
thanx,
that's because of the nature of the primitives and the curve you're drawing…
in short.. nurbs curves are based on point which doenst live on the curve itself.. so you might want to draw a polygon curve which instead have points on the curve…. over the nurbs surface.
hope this helps.
JcN
VisualCortexLab Ltd :: www.visualcortexlab.com
- Simon
- 2199 posts
