Viewer State Browser help
3052 14 0- Shadowjonny
- 97 posts
So i been reading all of Writing custom viewer states in Python for the past 2 days and followed the Loading a state from the Houdini path steps. Got everything working but im not seeing anything pop up on the console like it said it would. Also would this be the ideal way to check what the mouse is hovered over?
- mabelzile
- 398 posts
- mabelzile
- 398 posts
- Shadowjonny
- 97 posts
mabelzile
Here's an OBJ state I created with the viewer state code generator.Image Not Found
Thank you for the video, got it working but how come the documentation does it different. Are they out of date? also i check what stateutils module has and theres nothing in it also, so why is it in the the code snippet for example?
Edited by Shadowjonny - Jan. 9, 2020 16:41:16
- mabelzile
- 398 posts
Shadowjonnymabelzile
Which example are you referring to ? stateutils is just a module importing everything from viewerstate.utils and was kept to avoid breaking clients code.
- Shadowjonny
- 97 posts
mabelzileShadowjonnymabelzile
https://www.sidefx.com/docs/houdini/hom/python_states.html [www.sidefx.com] was following the “Loading a state from the Houdini path”. Also you are right it does lead to viewerstate.utils, but some how the documentation just somehow confuse me. Like i just want to know what each function does inside those modules and start building, i have to either test it out or open the modules with pycharm to see what it returns. Also quick question where can i find what “ui_event” does cause i see it with all the states, isnt that the same as hou.UIEvent but i get an error when i put that in the code snippet for the State.
ui_event = kwargs["ui_event"]
- AlanZ
- 41 posts
Shadowjonny
Hi Jonny, not sure if I get your question, but I think
kwargs["ui_event"]
Edited by AlanZ - Jan. 11, 2020 13:09:38
- Shadowjonny
- 97 posts
AlanZShadowjonny
Hi Jonny, not sure if I get your question, but I thinkindeed returns an instance of hou.UIEvent? You can then call its methods like hou.UIEvent.device(), hou.UIEvent.reason(), etc.kwargs["ui_event"]
Indeed i agree it is that but i want to know where i can get a list of things i can put inside kwargs. Cause i got an error when i put:
node = kwargs['node'] #inside OnMouseEvent for State got an error
yet i see it in the code snippet for example in the python state viewer documentation.
Edited by Shadowjonny - Jan. 11, 2020 14:14:36
- AlanZ
- 41 posts
Shadowjonny
I see. kwargs is different for different methods in your State. Since it's a dictionary, you can just print out its keys to inspect.
def onMouseEvent(self, kwargs): print kwargs.keys() # or "print (kwargs.keys())" in Python 3 #['node', 'state_flags', 'state_parms', 'ui_event']
kwargs['node']
- mabelzile
- 398 posts
Shadowjonnykwargs is the dictionary holding the arguments passed to event handlers, it's documented documented here [www.sidefx.com]AlanZShadowjonny
Indeed i agree it is that but i want to know where i can get a list of things i can put inside kwargs. Cause i got an error when i put:node = kwargs['node'] #inside OnMouseEvent for State got an error
- Shadowjonny
- 97 posts
AlanZShadowjonny
I see. kwargs is different for different methods in your State. Since it's a dictionary, you can just print out its keys to inspect.def onMouseEvent(self, kwargs): print kwargs.keys() # or "print (kwargs.keys())" in Python 3 #['node', 'state_flags', 'state_parms', 'ui_event']shouldn't generate an error though. Can u post a screenshot or something?kwargs['node']
just tested again and its working guess i typed it wrong when i first was typing it last night. My bad
- Shadowjonny
- 97 posts
- Shadowjonny
- 97 posts
- Shadowjonny
- 97 posts
mabelzileShadowjonnykwargs is the dictionary holding the arguments passed to event handlers, it's documented documented here [www.sidefx.com]AlanZShadowjonny
Been stuck with trying to select a point in the viewport, what would you say im missing or doing wrong? been going through the selection_demo and it doesnt really help me understand how it got to be able to select from prim to points. Im trying to select self points not the points from the connected node in 0.
import hou import hdefereval import viewerstate.utils as su def _refreshDrawables(state): """ Creates a drawable for each point added. """ pointCount = state.pointCount() if state.clear_drawables: state.drawables = [] for index in range(pointCount): state.addDrawable(index) state.clear_drawables = False elif state.add_drawable: state.addDrawable(pointCount-1) state.add_drawable = False state.scene_viewer.curViewport().draw() state.post = True class State(object): def __init__(self, state_name, scene_viewer): self.state_name = state_name self.scene_viewer = scene_viewer self.pressed = False self.index = 0 self.node = None self.drawables = [] self.post = True self.clear_drawables = False self.add_drawable = False def onEnter(self,kwargs): """ Called on node bound states when it starts """ self.node = kwargs["node"] self.node.addEventCallback([hou.nodeEventType.ParmTupleChanged], self.nodeParmCB) # post a refresh to draw a point for the existing multiparms self.postRefreshDrawables(clear=True) def onExit(self,kwargs): """ Called when the state terminates """ self.node.removeAllEventCallbacks() def onInterrupt(self, kwargs): """ Called when the state is interrupted e.g when the mouse moves outside the viewport """ self.finish() def onMouseEvent(self, kwargs): """ Process mouse events """ ui_event = kwargs["ui_event"] device = ui_event.device() origin, direction = ui_event.ray() inputs = self.node.inputs() # Only try intersecting geometry if this node has input geo_intersector = None if inputs and inputs[0]: geometry = inputs[0].geometry() geo_intersector = su.GeometryIntersector(geometry, scene_viewer=self.scene_viewer) isGeo = None if geo_intersector: isGeo = geo_intersector.intersect(origin, direction) position = geo_intersector.position # Create/move point if LMB is down if device.isLeftButton(): if isGeo == True: self.start() self.setPoint(self.index, position) else: self.finish() # Must return True to consume the event return True def onDraw(self, kwargs): """ Called for rendering a state e.g. required for hou.AdvancedDrawable objects """ handle = kwargs["draw_handle"] for drawable in self.drawables: drawable.draw(handle) def onDrawInterrupt(self, kwargs): """ Called for rendering an interrupted state e.g. required for hou.AdvancedDrawable objects """ self.onDraw(kwargs) def PointSel(self,kwargs): sel = kwargs['selection'] ss = sel.selections() print(ss) def onSelection(self, kwargs): """ Called when a selector has selected something """ state_parms = kwargs["state_parms"] self.log(kwargs) # Must return True to accept the selection return self.PointSel(kwargs) def onStartSelection(self, kwargs): """ Called when a bound selector has been started """ self.log(kwargs) def nodeParmCB(self, **kwargs): """ Clear the point drawables if something has changed on the multiparm. """ self.postRefreshDrawables(clear=True) def postRefreshDrawables(self, **kwargs): """ Post a job on the UI queue to refresh the drawables. Only one job at a time can be posted. """ if self.post: try: self.clear_drawables = kwargs['clear'] self.add_drawable = False except: try: self.add_drawable = kwargs['add'] self.clear_drawables = False except: pass hdefereval.executeDeferred(_refreshDrawables, self) self.post = False def addDrawable(self, index): """ Creates a sphere drawable for each multiparm point. """ pt_name = "pt%d" % index parm_tuple = self.node.parmTuple(pt_name) geo = hou.Geometry() sph_verb = hou.sopNodeTypeCategory().nodeVerb("sphere") # We want a polygon mesh sphere sph_verb.setParms({ "type": 2 }) sph_verb.execute(geo, []) drawable = hou.GeometryDrawable(self.scene_viewer, hou.drawableGeometryType.Line, "pt_hilite", geo ) drawable.show(True) rad = 0.05 pos = hou.Vector3(parm_tuple[0].evalAsFloat(), parm_tuple[1].evalAsFloat(), parm_tuple[2].evalAsFloat()) parms = { 'translate': (pos[0],pos[1],pos[2]), 'scale': (rad, rad, rad), "color1": (1.0,0.0,0.0,0.7) } drawable.setParams(parms) self.drawables.append(drawable) def pointCount(self): """ This is how you get the number of instances in a multiparm. """ try: multiparm = self.node.parm("points") return multiparm.evalAsInt() except: return 0 def insertPoint(self): index = self.pointCount() multiparm = self.node.parm("points") multiparm.insertMultiParmInstance(index) return index def setPoint(self, index, position): self.node.parm("usept%d" % index).set(1) self.node.parmTuple("pt%d" % index).set(position) def start(self): if not self.pressed: self.scene_viewer.beginStateUndo("Add point") self.postRefreshDrawables(add=True) self.index = self.insertPoint() self.pressed = True def finish(self): if self.pressed: self.scene_viewer.endStateUndo() self.pressed = False def createViewerStateTemplate(): """ Mandatory entry point to create and return the viewer state template to register. """ state_typename = kwargs["type"].definition().sections()["DefaultState"].contents() state_label = "Pipe Setup System" state_cat = hou.sopNodeTypeCategory() template = hou.ViewerStateTemplate(state_typename, state_label, state_cat) template.bindFactory(State) template.bindIcon(kwargs["type"].icon()) KeyStart = su.hotkey(state_typename, 'Point Selection','1') template.bindGeometrySelector(prompt="Point Selection", allow_drag=True, quick_select=True, auto_start=True, use_existing_selection=False, consume_selection=True, secure_selection=hou.secureSelectionOption.Off, initial_selection="*", initial_selection_type=hou.geometryType.Points, geometry_types=(hou.geometryType.Points,), hotkey=KeyStart, name="PointSelector") return template
Edited by Shadowjonny - Jan. 21, 2020 16:28:32
- Shadowjonny
- 97 posts
