Possible Minor Bug
Houdini: 8.1.796
Distribution Build: Windows
Objectmerge seems to have problems with mirrored paths
A path mirrored in the OBJ scope is not merged correctly into a SOP with Objectmerge. The mirroring seems to be undone.
OBJ Paths
SOP ObjectMerge
BUG: Objectmerge and Mirrored paths
3985 4 2- kgoossens
- 289 posts
- edward
- 7722 posts
- kgoossens
- 289 posts
edward
Make sure you have “.” (dot) as the value of your Transform Object parameter.
Hi Edward,
I'm not sure what you mean.
What I did is, I used the mirror function and then with an Objectmerge I merged the convertSOP (from the path OBJ) in the rig.
Which transform of which node should I check?
A computer is almost human - except that it does not blame its mistakes on another computer.
- Le_monkey_butt
- 166 posts
- edward
- 7722 posts
