I'm working on terrain creation that would be split for composition in unreal with PDG and houdini-engine-v2. I followed that awesome tutorial: https://www.sidefx.com/tutorials/procedural-desert/ [www.sidefx.com]
However I had few PDG setup problems and I would like to understand a bit more about tags:
Here is my setup:
SOP HDA to create terrain (terrain_setup.hda)
-- One output (I would expect SOP)
SOP HDA to setup terrain (terrain_split.hda)
-- One SOP input to get the height field
-- One Output (I would expect SOP)
TOP node
-- hda processor from "terrain_setup.hda"
---- Create output with outputtag="mytag"
-- wedge to create attribute tile_NP
-- hda processor from "terrain_split.hda"
---- Reads input with "mytag"
---- Create output with "file/terrainsplit"
If my output tags (in asset output) are "file/geo" for all my hdaprocessors, I have the following error:
ERROR:root:Traceback (most recent call last):
File "C:/Users/pouke/AppData/Local/Temp/houdini_temp/generate_terrain/pdgtemp/8128/scripts/hdaprocessor.py", line 876, in
main()
File "C:/Users/pouke/AppData/Local/Temp/houdini_temp/generate_terrain/pdgtemp/8128/scripts/hdaprocessor.py", line 872, in main
run_job_mode()
File "C:/Users/pouke/AppData/Local/Temp/houdini_temp/generate_terrain/pdgtemp/8128/scripts/hdaprocessor.py", line 736, in run_job_mode
result = hda_service.run_job(work_item, temp_dir)
File "C:/Users/pouke/AppData/Local/Temp/houdini_temp/generate_terrain/pdgtemp/8128/scripts/hdaprocessor.py", line 435, in run_job
result = self._setup_scene(work_item, temp_dir)
File "C:/Users/pouke/AppData/Local/Temp/houdini_temp/generate_terrain/pdgtemp/8128/scripts/hdaprocessor.py", line 408, in _setup_scene
self._setup_file_inputs(work_item, hda)
File "C:/Users/pouke/AppData/Local/Temp/houdini_temp/generate_terrain/pdgtemp/8128/scripts/hdaprocessor.py", line 346, in _setup_file_inputs
self.installed_hdas[hda]['hda_node'].setInput(i, filenode)
File "C:/PROGRA~1/SIDEEF~1/HOUDIN~1.408/houdini/python2.7libs\hou.py", line 13211, in setInput
return _hou.Node_setInput(self, input_index, item_to_become_input, output_index)
InvalidInput: Invalid input.
From what I understand PDG reader can't make difference between different outputs created by different hda processors.
Someone could explain me how tags are working in PDG, why is it set to "file/geo" by default and where tag are saved?
